I have one 40GB Seagate drive and one 40GB WD drive. I had my WD drive in another computer and when I stuck it in the box that has the Seagate drive, the Seagate suddenly went slow. The Seagate drive has Windows installed on it and everythhing moves slow. Opening IE or even My computer will raise the CPU usage to 80%-90%. Coyping a file on the Seagate drive will make my CPU usage skyrocket while doing anything on the WD drive it will stay low and normal. Coying a file on the Seagate also take about 3 times longer then the WD drive. This leads me to believe that it is the HD's fault, not windows.
What could be wrong, did a setting get chenged on the Seagate drive? How do I check if it is in DMA mode?
