From my understanding, it is a torque converter that uses a magnetic field as the fluid.
The needle is basically a spring wound indicator and the further you turn, the more reaction force it makes. The higher the input shaft's rotation, the more torque it induces on the needle to read the speed.
I'm experiencing bizarre things with my speedometer.
After I put way too much grease in cable, it wouldn't read over 20 mph. The odometer was still rolling fine.
I wiped it off.. and it works, but it tends to stick around 60mph and wobbles below 40mph.
Since odometer is accumulating total mileage file, it's not a slip.
If the output and input aren't in perfect sync, the output is probably fluttering and I can understand how that would make the needle flutter, but how does it explain all the other weird behavior like delayed response?
