ECS K7S5A Temperature Monitor?
HendrixFan
4,646
Is there any utility that works specifically with the ECS K7S5A board to monitor the temperatures, or do I have to use 3rd party software?
tenoc
1,270
There is monitoring in the BIOS, otherwise, there are a number of third-party solutions.
athlonator
37
Incidently I jut hooked up my K7S5A yesterday, and went in search for the perfect temperature monitor.
After testing a few, I found "Motherboard Monitor 5" to be the best. Link
Be sure to look at the setup page for the sensors as well. Link
Also be sure to take some time and play with the software, as it has a lot of functionality and takes some time to setup
correctly. A lot of things are not apparent at first, but takes some time. Along with sensing, it also allows you to
set limits(upper and lower) for the temperatures and voltages, beyong which it can sound an alarm, or turn off the computer.
I got it running displaying my two motherboard temp. sensors(cpu and case), and two fans(cpu and case) perfectly.
