SunnyD
Belgian Waffler
Hehe... I bet you're all thinking "oh, another one bites the dust"... whelp, nope. Everything seems to be running smoothly. I just have a few simple questions regarding this motherboard that someone might just be able to help me with.
#1 - I need to get the latest BIOS installed on this board, but I now (regretfully) realized this board comes equipped with an AMI BIOS. I'm from the land of Award where you can update the BIOS from any OS, just format a floppy, copy the .bin file on it, reboot and hit F2 to flash.
Problem is, I'm running WinXP, and don't have access at this moment to a DOS boot floppy (I have one somewhere, probably in storage). Is there any way to update the BIOS safely and reliably via some other means, or do I absolutely need a boot floppy?
#2 -I just plugged in my headphones to the onboard sound. Yeah yeah, get a real soundcard you say. But the whole point was to put together an inexpensive system (which for $250 I think I did pretty well)... Anyway, my gripe/question is: The volume on the output is extremely low, with both WAVE and MAIN volumes in windows turned to max. Is there any way to fix this?
#3 - What other patches for this motherboard should I be using? Direct from SiS? From ECS? Audio drivers? What.
Thankee, and other than that, all is well.
SunnyD (So far relatively happy with this board)
