- Mar 1, 2003
- 354
- 0
- 0
blackinches would like to know what the fastest processor the k7s5a can support is. blackinches appreciates any helpful replies and possibly even some not so helpful replies.
blackinches should learn how to use the search button and should stop writing in the third fvckin' person.![]()
No.. Not actually. I just bought a Shuttle board with a cpu combo and the thing runs way too hot, while the ECS Pro board runs at a nice and steady temp even under load.THAT IS THE WORST MOBO EVER
Actually.. I still need a question answered about my Shuttle board. After the second run with SiSoft Sandra's burn in, it shuts down because the temps spike. The board temps go from about 40 degrees Celsius at start to over 60 degree Celsius by the second run and then shuts down under Sandra's default temp protection. Is this normal? It even does it at the normal setting in Sandra's burn in. My ECS K7S5A Pro board runs at a steady 37 degrees Celsius in the same case even under the the high stress setting. I can run Sandra all day with the ECS board and it won't flinch.
So.. Why is the ECS board bad? A lot of people bought them and because a lot of people buy them, more are reported as bad? I haven't seen one other mention of the AK32VN Shuttle board that I just bought. Nobody seemed to buy this board.
Sal
Salvador wants to know. Now! Salvador is confused and doesn't know what to do.No questions answered in this thread unless asked in the third person!
Salvador will have to check and see if the temps spike with the case open. Salvador put another board in this same case and the temps didn't spike like this though.Sal how is the case ventillation? Do the temperatures spike with the case cover off? I'd also check that the HS is making good contact with the core.
How would Salvador go about checking if the sensor is accurate? Salvador is running out of time with this board. Salvador only has 4 days left to exchange it or he has to RMA it to Shuttle later.DieHardware wonders if the Shuttle's MB sensor is accurate, if it is, DieHardware thinks you should check both.
Originally posted by: tenoc
Actually, it will take a 2600+ (266) with the right bios, if you can find one.
Does this apply to the original K7S5A, and if so, is the "right BIOS" different from the latest version on the ECS web site?
Heh.. It's hard to go back to writing in first person after writing in third person.
Sal
