ecommerce, UltraCart vs Homestead store front
Emulex
9,759
most of the cheap cart stuff from the usa is junk. batavia is almost decent and has a good set of features that you would have expected from a next generation oscommerce.
Captain Midnight
I am using Homestead Storefront and am still working on getting everything set up properly. I chose them due to their integration with quickbooks software and merchant services. Their support staff is quick to answer the phone, however, it is luck of the draw when it comes to getting someone who can answer the question. Homestead's service is suffering since their aquisition by Intuit. Intuit has the worst support I have ever encountered. The advertised integration with quickbooks has been problematic, and their final solution to our troubles was that the StoreSync software (that is responsible for the integration between the website and quickbooks) does not run properly in windows vista. They suggested rolling back to XP... I am considering GoDaddy's offering, has anyone had any luck with Quick Shopping Cart?
