For some reason yesterday my sound just started to echo on me. I didn't change any settings or do anything differently then I normally do. I have a soundblaster audigy gamer. Any help would be great.
You probably have your Reverb set higher than it should be 🙂
Go into your creative mixer or whatever software came with the Audigy and there should be some sort of EAX settings area.... then just turn down the reverb or change the preset (like they have a list of "presets" ie bathroom etc), back to its default.
No it had nothing to do with my reverb, and oddly enough just as weird as it came it disappeared. I didn't do anything different. Maybe a loose cord or something I dunno?
