What is going on here?
http://img100.imageshack.us/img100/7863/temp3lj.png
a). Draw an equivalent circuit clearly showing ?ground? (reference) node. (25 points)
b). Calculate current flowing through the 1K resistor and identify its direction (30 points)
c). Calculate voltage of the Signal out at device (45 points).
Help & Hints:
It?s sometimes acceptable to identify output terminals (such as Signal out at device) without explicitly referencing them to ground node. So, what that means in this case is that you should find a voltage between the node closest to the said output terminal and ground.
I'm not understanding the diagram at all. 1.5V is the ground reference node, but what's that 3.3V doing? It's not even in a loop, so does that mean that the circuit is equivalent to
http://img193.imageshack.us/img193/5766/temp20eb.png
We're currently doing nodal analysis but all of our examples have been nice little loops or multiloops. We've never had something where the circuit was not a loop (the signal out just kinda terminates).
TIA
Help & Hints:
TIA
