karmasalad
Well, I recently swapped out the original Antec PSU from my case with the Seasonic SS300, and the decrease in noise has been wonderful. But the problem now is that the whine of the HSF on my PIII 1GHz is driving me nuts.
Is it possible for me to just remove the fan, keep the stock heatsink, and mount an 80mm fan using the FB123 fan bracket? I have an extra NMB fan from SVC lying around. Will this be safe and adequate cooling? Or would I need a bigger/stronger fan?
I don't really want to go through the trouble and cost of getting a whole new HSF assembly for this old machine.
Currently, with the stock HSF, my CPU idles between 32C ~ 36C, depending on ambient temperature. Under load, the highest I've seen it go is 45C. However, I'll be converting this into a home server soon, so the computer won't be taxed much other than transferring files.
Thanks for any advice,
Peter
Peter
