Easy reset function for Xbox?
edro
Isn't there a certain button combination or something that will reset the Xbox?
How about a DVD remote that will reset it?
Anyone know?
Thanks!
Take the controller and bang it against your head. I know you think I am lying , but it really works.
Originally posted by: Cashmoney995
Get a really long stick, and poke until you hit the reset button.
BAHAHAHAHA! That is what I do now! I use a pool stick! HahAHAHAH
There actually is a way to mount a momentary switch on the controller and do a little soldering in the box itself to make a remote power button. There is a extra wire in the controller and xbox that is used, just means you can't use a light gun on that port. The tutorial for it is on xbox-scene.
may I ask how heavy u are?
168lbs this morning. I have it modded, so I switch between games a lot.
Well if its modded just do a IGR (in game reset)
DOH! I didn't even know they called it IGR. I looked that up and found out it is L+R+BACK+START... and it works.
THanks!
just FYI, turning it on and off several times instead of reseting it rapes the lifespan of the unit in general.
THanks!
Did you even read the 2nd post in this thread?
