Easy n00b Java help #40545
ChrisCramer247
2,171
Hey Everyone. I'm stuck on this one part of my program. Not sure if I can maintain this in Main or need a seperate call to a method. Here were the instructions given:
1. Set up the program for keyboard entry (I declared this as static and global)
2. in the main method, use a for loop to ask for each of the five numbers as follows: (this is what im unsure about
for (int x=1;x<=5;x++){
try{
display(?Please enter number ?+x+?: ?);
String input = keyboard.readLine();
number=Integer.parseInt(input);
catch(NumberFormatException e){
display(?I was expecting an integer.?);
exitProgram();
Here is the source code I have so far, if anyone can help it would be greatly appreciated THANKS!
import java.io.*;
public class AverageFive {
static BufferedReader keyboard = new BufferedReader(new InputStreamReader(System.in));
//***--------------------------------Begin Main------------------
public static void main(String args[]) throws IOException {
int x = 0;
String input = null;
//THIS IS WHERE IT GETS BAD, DO I NEED A SEPERATE METHOD OR CAN I KEEP IT IN MAIN?
try{
display("please enter a number "+x+": ");
display ("I was expecting and integer.");
System.exit(0);
//***------------------Begin Display----------------------
public static void display(String n){
System.out.println(n);
}//close display
}//close AverageFive
manly
13,086
3,850
For a program this small, you don't really need to factor your code into separate functions, or modules.
RRZReme
23
Why don't you read your input into a character array and then just check the array for any numbers?
BTW, global variables are BAD BAD BAD
