Easy CD Creator - Loses track of burner
EagleKeeper
Discussion Club Moderator<br>Elite Member
Staff member
Oct 30, 2000
42,589
When ever I switch/add hard drives to the system, the CD drive letter changes and the burner S/W complains that it can not find a recognized burner.
I have installed Easy CD Creator that came with my burner when the drive was L:
Learning my lesson after the fact, I have assigned the CD burner to drive Z:
I can read/write to Z: using CloneCD, but my better half is used to CD Creator for burning her music mixes.
Can anyone point to the proper settings to change the drive letter reference that is used by the S/W
I do not wish to have to re-install the S/W again. Have already done it 3-4 times as I switched H/W around.
Also, can any of the other music players that are floating around do the burning, ie Media Player, Real Player, Win Amp, etc.?
Thanks
corkyg
Elite Member | Peripherals
27,370
239
In ECDC 5, to change drive letters. use TOOLS, Drive Properties. In general, players can't burn.
richleader
1,201
Older versions of clone Cd (prior to burnproof) can make a cd writer dissappear in roxio if you install clonecd after the roxio, installing roxio again usually makes them both work with the cd writer. May be your issue, but probably not. :confused:
EagleKeeper
Staff member
Oct 30, 2000
42,589
Problem existed prior to installing CloneCD
