- Mar 30, 2001
- 140
- 0
- 0
I have Easy CD 5.0 with the latest updates 5.02B installed in XP and cant get Easy CD to make a data cd. It stops as soon as I tell it to make the CD and reports Errors reported by output device. What gives? Direct CD works fine writing to CDRWs.
The funny thing is I had the thing working when I originally did a fresh install of XP and just installed Easy CD Platinum 5.0 with no updates back before they came out with the new XP compatible updates. The only problem I had was my computer would reboot instead of shutting down.
I did a clean install of XP back when the new XP updates where released and installed them following their instructions at the time. I had only used direct cd since then with no problems. Today was the first time I got around to making a data cd on a CDR and it wont work. Thanks for any help. I really am not liking Easy CD right now. Probably should have went with Nero.
