Easiest way to cool a bottle of beer from room temperature to serving temp?
Cdubneeddeal
7,473
Once when I was bored, me and my bro-in-law used a bunch of leftover mostly empty canned air sprays upside down on a 6-pack. It was outside in August, and we got the things really frosty despite the heat.
Did you huff them too?
AnonymouseUser
9,943
107
Exactly. The salt allows the solution to remain liquid while below the freezing point of water, but doesn't inherently make the water any colder.
Salt does make the water colder in the presence of ice. This is why it was commonly used to make ice cream. According to this chemist, the water can drop to as low as -21C before freezing.
Born2bwire
9,840
Ice absorbs energy to melt. Normally in ice water the ice draws heat from the surrounding air since the water is the same temperature as the ice (the water doesn't freeze because it has to release extra energy to freeze, without the presence of colder objects all it can do is hover at the freezing point). The salt lowers the freezing point of the water so that the water can drop to a lower temperature before it hits the temperature barrier. So now the melting ice absorbs heat from the surrounding water and lowers the temperature of the ice-salt water solution lower than 0 Grad.
BigPoppa
Salt will allow the temperature of the mixture to lower, but its not going to lower it all by itself unless the ice itself is that temperature. Can't make it colder than the ice is, is what some are trying to say.
RedCOMET
2,836
how does the salt help? Why not fresh water ice?
also Mythbuster did something on it:
http://en.wikipedia.org/wiki/MythBusters_(2005_season)#Episode_29_.E2.80.93_.22Cooling_a_Six_pack.22
http://kwc.org/mythbusters/2005/03/mythbusters_cooling_a_sixpack.html
Just in case you didn't believe that fancy Chemist :)
Babbles
8,253
14
First make sure you always have beer in the fridge. I'm pretty sure that ranks high on the list of Man Laws.
As others have noted ice water with salt will get the water "colder" and therefore the beer "colder" than just ice water by itself. That entire freezing point depression thing.
<--- Analytical CHEMIST for ~ten years. . . have done the salt water ice bath many times in the lab
GagHalfrunt
25,284
1,998
This works GREAT, but refilling the extinguisher gets a bit expensive...:p
It also has to be done one beer at a time. With the salt water bath you can do cases at a time provided you have a large enough container. I've done the salt water thing for years before Mythbusters did it on TV, it's one of the first things you learn in college. Works great. You can go to the package store and bring back 10 cases of room temperature beer and have every single can cold in 5 minutes. You'd need every fire extinguisher on campus to do that if you tried it that way.
Sloper
85
Salt makes the freezing point significant lower. BUT you need a driving force to bring the temp down that low. If you take add salt to water and dump in a bunch of normal 0C ice blocks, the coldest the salt water ice bath gets is still 0C.
Babbles
8,253
14
Chances are the ice is colder than 0ºC. I'm not really sure what the typical operating temperature of a home freezer is, but I would imagine it is something in the -15 to -20º region. The ice cubes should retain that temperature (or close to it) and therefore will not merely be at the freezing point of water.
Also as an aside, it may be a wise idea to crush the ice, sprinkle some salt on it then shove your can of beer into the crushed ice. I really haven't tried that method myself, but I wonder if increasing the surface area of crushed ice would be better.
Rubycon
Madame President
Aug 10, 2005
17,768
485
Just pour the salt in the beer. Those pissy American lagers will definitely taste better. :p
isekii
28,578
Easiest Way~ run out to your local 7-11 or Wawa and get a bag or two of ice. throw it in a cooler with some water. and dip your beer in.
surfsatwerk
10,110
The frozen corpse of a dead hobo and a wee bit of lube. You can figure out the rest for yourself.
drinkmorejava
3,567
7
But the ice cubes are not what is covering most of the surface area of the beer bottle, so the temp of the ice cubes is not relevant. The water itself cannot go below 32F without freezing, just as boiling water cannot go above 212F at 1atm.
mugs
48,920
46
It can if it contains salt
Hacp
13,923
You sir are wrong.
Zargon
12,218
It's the temperature that cools the beer, though; not the state of matter. I do not understand. :(
the temperature of the ice is significantly below 32F
it can cool the water to a temp below freezing, which without the salt, would get your beer stuck inside an iceberg.
its like, the first thing you should learn when having a college party in a warm climate
Jeff7
41,596
20
Easiest? Refrigerator or freezer.
Quickest? Mythbusters tried it with some ideas that involve some construction work.
But here's one that just came to mind: Spray the beer through a mister within a cold environment. The tiny droplets can expel heat very quickly to the surroundings, allowing for rapid cooldown. Downside: It'll probably let out a lot of the carbonation.
