And also the most cost effective 🙂
Hi everyone, I want to stream movies and shows on my TV and I'm not clear as to what direction to go in. I should have figured this out on my own but didn't.
My main priority is to stream content from the PC to TV. I used to have a long HDMI cable running from my PC to my TV. Well, I have a new PC and it is now not very convenient to go this route. So now, I'm wondering what is a good alternative.
The first choice is Chromecast because of the price and also since it can stream content from PC to TV. However, there are limitations, such as Amazon Prime not being available and that its not always easy to stream everything from PC to TV. Some content is not supported by Chromecast and thus cannot be streamed. Also, I'm not sure if it can consistently play 1080P videos.
The second choice is Roku 3. I believe this is a good choice because of a wider choice of content and channels. But this will be completely independent of the PC. I will simply have to do everything from the Roku remote, which I'm not sure will be as easy to search content. With the PC, it is very easy to search using the mouse and keyboard.
The other choice is the Wii U. However, I'm not sure if it will consistently stream 1080P content. The same goes for the other devices. Do they consistently stream 1080P content?
I may just get the Wii U first since its much more than a streaming device. If it does play content well, then there may not be a need for anything else.
As you all can see, I'm a bit lost. If only there was a way to wirelessly transmit PC content to the TV, that would be great.
Appreciate any comments. Thanks.
