e8400 mobo and memory ..$300 to spend.. possible?
magnumty
115
I have about 300 to spend on and upgrade, is it possible to get the chip, mobo, and 2 gigs of memory for 300? I prefer to use newegg. any suggestions appreciated.. doesent have to be a super overclocker.. thanks.
myocardia
9,291
30
No, it's gonna cost you ~$400 right now for an E8400, P35 motherboard and 2x1 GB of RAM from newegg, if you include the shipping costs.
BlueWeasel
15,944
475
Actually, depending on the current RAM deals, he might be able to get all of that for ~$360. Maybe slightly less if you include rebates.
taltamir
13,576
http://www.mwave.com/mwave/Dee...teria=e8400&ALL=y&TP=4
e8400 for 209+7$ shipping (8$ for 3rd day, 10$ for 2nd day air)
http://www.newegg.com/Product/...x?Item=N82E16813128059
89$ with free shipping
P35 mobo. relatively good. should oc to 4Ghz on quality air with quality ram.
Grand total 305$
I got that, but paid extra 60$ on mobo to get one with a ICH9R south bridge (GA-EP35-DS3R) cause I needed the extra SATA ports (I got multiple raid arrays)
Oh I forgot the ram.. you can get almost any 2x1GB pack of quality ram for 20$ after rebate.
toslat
216
HP DDR2-667 Value RAM was FAR with $7 shipping from antonline.com not sure if deal is still on
Depending on taxes and availability in ur state, the microcenter $189 E8400 might be cheaper.
hans007
20,212
18
$300 is doable. you can get a $189 e8400 (theres a few places online, though newegg isnt one of them)
newegg is $219.99 free shipping
http://www.newegg.com/Product/...E16819115037&Tpk=e8400
this gigabye g31 board is actualy fairly well recommended as the best g31
http://www.newegg.com/Product/...x?Item=N82E16813128078
its $67 + $6
there is also an ecs g31 for $55 after mail in rebate of $20 and it also has free shipping (you might be better of getting the gigabye though, i guess if you dont o/c it really doesnt matter)
wintec ddr2-800 2gb is $38.99 + $5 shipping (i actually have this memory and its fine and works great)
http://www.newegg.com/Product/...x?Item=N82E16820161172
memory has gone up slightly the last couple weeks... but still its definitely doable. newegg had some ddr2-667 for $3 less too.
so thats $39+5+67+6 =$114
plus the $189 e8400 and whatever shipping is for that. its not quite $300, but its barely over like $303. + taxes and whatever shipping is on the e8400 (or if he has a microcenter local he can get it there for $189.99)
i guess if he went all through newegg, got ddr2-667 and the ecs after rebate, and the newegg e8400 its $220+$55 after rebate, + $35.99 + 5 ddr2-667....
so thats $314 if he does it all through newegg at the absolute minimum with a rebate.
hans007
20,212
18
Originally posted by: justlnluck
If you don't overclock, is there a benefit of 800 vs 667 ram?
if you dont overclock there is no benefit if you do dual channel.
667 x 2 @ 64bit memory bus, = 1333 @ 64bit processor bus.
the only advantage is for integrated video bandwidth...
