I've read boatloads of posts, articles and reviews on the e8400 and all the usual problems with them. I just recently fired mine up in an Abit IP35 Pro and I appear to have one of the stuck temp sensors or a BIOS that won't properly report temps. I am running the BIOS that came with the board since I haven't had any problems. I haven't counted that out as a potential reason for the temp issue. RealTemp and Coretemp both show idle of 47C. After running Orthos for 20 mins, temp does not change at all. Nothing I have done changes the 47C reading, it has never showed up even 1C off of 47C.
Just a few questions that I couldn't seem to find a definite answer to while googling and looking here...
The IP35 Pro is running BIOS 6.00PG according to CPU-Z 1.50. Would updating the BIOS help the stuck temp readings? I wasn't even sure the e8400 would run properly on this BIOS, but it's chugging along just fine.
Most of what I read indicated that the temp sensor could be stuck permanently, but I have read that lower than normal temperatures could cause the temp to lock at a fixed number until temps rise above where that lock occurs. It's admittedly cold in my office right now. I have a Zalman ZM-MFC2 fan control with the probes set up to take intake airflow readings from the vital parts like the HDD area, PSU, GPU etc.. The probes read 21-23C over the last few days. Could this low temperature be causing the sensor to lock up?
Some pertinent info:
Cooling: Thermalright Ultra Extreme w/ Ceramique, 120mm Yate Loon DM12-SM fan @ 1k RPM
Case: P182, 5 total of the same YL fan, all at 1k RPM, cables are tidy so really good airflow
