- Feb 5, 2006
- 2,778
- 1
- 81
So I have a E7200 and a Gigabyte 965P-DS3 with latest bios. The E7200 is stepping M0.
I have the FSB at 350 with a 9x multi = 3150 Ghz. the Voltage setting is on auto, which says 1.25 at the bios. Thing is when I check on cpu-z it shows up as 1.360 voltage. When I try to manually set the voltage it becomes unstable. Is there something I'm missing here?
CPUID HWMonitor idle temp is 51c/47c..
thanks
thanks
