What should I use to monitor the temps - right now I am using the asus tool that came with the MB - reads the same as the BIOS
at stock speeds with stock votlages my idle cpu temp is ~ 48 and the motherboard temp is ~ 43 - while ambient room temp right next to the pc is ~ 27-29
I was hoping to get a decent overclock - but I need to get the temps under control 1st
the fans are all on full speed (fan-control turned off via the bios). I have a passive xfx-7950gt video card - but a 120mm case fan (mounted on the side cover) is blowing on it- corsair 520 psu, 120mm front and rear fan.
Other than trying to reclean & reseat the cpu cooler (which was applied w/ arctic silver following the directions on their site - 1 strip down the center of the cpu) - any thing else I should be trying to lower the temps.
Cables are somewhat cleaned up - so shouldn't be a big problem
