- Mar 24, 2005
- 2,055
- 9
- 81
UPDATE: at 2.94 GHz (7x420FSB), still 1.3625v, the system *seems* stable. Processor temps are even higher, though, at up to 80C!!!
Hey, all. Here's the situation:
CPU: E6300
cooler: retail hsf
board: Gigabyte GA-965P-S3
RAM: 1GB (2x512MB) Corsair XMS2 DDR2-675
CPU voltage: 1.3625v (according to BIOS)
DDR2 voltage: "+0.1v" (according to BIOS)
"FSB" voltage: "+0.1v" (according to BIOS)
"MCH" voltage: "+0.1v" (according to BIOS)
FSB: 400 MHz
memory multiplier: 2
stock memory speed: DDR2-675
actual memory speed: DDR2-800
CPU multiplier: 7
stock CPU speed: 1.86 GHz
actual CPU speed: 2.80 GHz
I'm not sure what my normal idling speed is, but after running Orthos my temps fall to about 45C on idle. When I'm running Orthos on "blend" it can get to at least 70C (after about 8 minutes), though it seems to jump up and down an awful lot (from about 65-70C).
The voltages I have set in the BIOS are absolutely necessary to even boot the system. So far, I've only run Orthos for less than 20 minutes, so I may have to bump them up from there.
Now, I've heard that 1.4v is fine for an E6300, but I'm more concerned about the temps. I know I only have stock cooling, but I was under the impression that people could squeeze at least 3GHz out of an E6300, and certainly 2.8! Have I been mislead? Is 40-70C safe for extended use?
Also, how can I better monitor voltages and temps? Speedfan works fine for CPU temps, but what about everything else?
Thanks, everyone!
CPU: E6300
cooler: retail hsf
FSB: 400 MHz
CPU multiplier: 7
Thanks, everyone!
