Corporate Thug
According to hardware monitor and Speed fan, my e6300 (stock for the summer) is idles @ 52 (core 1)/53 (core 2) on a CNPS 9500AT.
Does that seem kinda high?
Originally posted by: BonzaiDuck
If you had one of the newer Wolfdale Penryns, I'd tell you to update the 680i BIOS (carefully) for the motherboard. But an e6300 is the last CPU I'd think would give you those results, unless you're room-ambient is like 110F.
If you're going to measure temperatures, use CoreTemp or RealTemp for the Conroe. Use RealTemp on the newer Penryn cores.
The Zalman CNPS 9500 is not "stellar," but it should be doing a better -- much better job than that.
