- Aug 25, 2001
- 56,587
- 10,227
- 126
My friend's rig has an IP35-E and an E5200. I built it for him. When we installed the E5200, we overclocked it to 3.75Ghz, at 1.425v (BIOS). Under load, it drops to 1.4v or a little under. It wasn't stable at any faster speeds with only that voltage, and I didn't want to go higher on voltage because I had heard that 1.4v was the safe max for 45nm chips.
Well, fast-forward to today. The guy from the electric company came to shut off his power, and actually did, for a few minutes, until my friend negotiated with him. Anyways, I was using his rig a little later in the day, and I noticed that it was no longer overclocked. So I restarted, went into BIOS, settings were still there, saved and exited, and went back into Windows XP. CoreTemp and CPU-Z then showed that it was overclocked. I had wanted to check the temps, so I ran Prime95 25.9 small FFTs. Within less than a minute, one of the cores errored out, at settings that had previously been stable when we originally set it up. I ran Prime95 again, thinking it was a fluke. Again, an error, this time on the other core.
So I went back into BIOS, and rather than crank up the voltage, I cranked the speed down. From 300FSB to 290FSB, 3.625Ghz.
This time, Prime95 seemed stable, at least for the few minutes that I tested it, but temps were horrible, 83C on both cores, with a TJmax of 100. So again, off the computer went, this time to get its insides blown out with some compressed air. I did that, and temps under Prime95 small FFT dropped to 67C on both cores. With a HyperTX2 cooler.
So tell me, is this an issue of the CPU degrading? Or the mobo degrading? Vcore under load reported the same values that it always has in CPU-Z, so it doesn't seem like the mobo is degrading. I don't think the dual-core draws that much power. So that leaves the CPU voltage, and lifespan of the chip. Does this mean that even 1.4v is NOT SAFE for 45nm dual-cores? If that's true, then a lot of people are going to be surprised, I think.
