E46 323i Limp Mode after Transmission replacement
Status
Not open for further replies.
xdopamine1
I have an E46 323i 1999 in limp mode! I ran the OBDII codes and popped up as P0734. I bought a reconstructed transmission, and rebuilt my original torque converter. The new transmission was installed and I switched out the TCM, and i'm still getting Limp mode after driving around for about 3 blocks, and a P0734 "Gear 4 incorrect ratio". I'm running out of ideas. and I'm desperate to get my car up and running some one help.
repoman0
5,191
4,573
I'd suggest checking out the forums at e46fanatics.com. They'll be a lot more help ...
nk215
403
If you ever get this resolved please follow up. I had the same code and fixed it with a transmission fluid/filter change. The code hasn't come back for a few weeks now but I don't think I got to the bottom of it.
Status
