Got an e4400 running at 3Ghz with 1.4 vcore and using the Arctic Cooling 7 Pro HSF to cool it. With the case open and cpu at idle my coretemp reading is 43 degrees with an ambient temp of 19 degrees. I've re-seated the HSF with a thin layer of AS5 and this temp stays constant. When I used orthos to test my system, the temp jumps up to 70 degrees. I let it run for 10 minutes and temp remained at 70. The HSF is not even warm to the touch but the NB heatsink of my Gigabyte P965-S3 mobo is too hot to touch. Are my temps too high or is this what I should be seeing?
