One would assume that you could also pin mod the E21x0's as well. Am I correct?Originally posted by: PCTC2
But if you get an E4x00 series Core2, I reccommend pin-modding them to the 1066FSB strap. The E4500 would boot at 2.9GHz default. If you're really adventurous, you could double-pin mod a E4400 to the 1333FSB strap, and boot at 3.333GHz default.
Where would I find a photo/explanation of the procedure? Also, can the pin mod be reversed?
Thanks
Hermit
Originally posted by: boomhower
I believe that all the e4500 are MO steppings. While I would agree that typically going for the higher multiplier is better, but I have heard more people having trouble OCing e4400's than I have E4300's. It doesn't make a lot of sense to me either. For overclocking a MO stepping gives you a lot headroom .
Good data. What kind of cooling? Stock?Originally posted by: Greg04
Just weighing in --- Got three e4500 retails from mwave.com and all three go to at least 3.3 @1.4v on a IP35E
Thanks
Hermit
