E-Machine Will not turn on/Post
ComputerWizKid
My friend has an older E-Machine Model T3828 and I was asked to check it out why it will not power up. I tested everything (Except the CPU) I had him order a "New" board and I put the "New" board in with the CPU and it will still not power on/POST. I went as far as testing everything that I could with the parts I had on hand (Which leaves out the CPU as I did not have another Socket 478 Board to test and I also did not have another CPU either :twisted🙂 I also did test it with it out of the case and still no go
Anyone have any ideas or things I could have missed and can a bad CPU Cause the board to not even turn on?
Thanks
I have a special tool for fixing such a computer. I call it the Justice Machine. 1 potato stuffed into a 2"x4' barrel accelerated by 100+ psi of compressed air will take care of your problems right quick.
Really though, I had a similar problem with an E-Machine when I worked for Circuit City Firedog. They hardly provided the techs with any extra hardware to test with there, and after ordering in a replacement MB, then later replacement RAM (both with no success), I asked that the parts provider send a new CPU, PS, and HDD, because the customer was not happy waiting (which I understand, even though the policy clearly said it could take up to a month). Replacing everything with the new parts fixed it, then I tested with the old HDD which was fine. I would have liked to have troubleshooted more to find out what exactly was wrong, but the techs were very understaffed there, so that wasn't reasonable.
I believe it is possible for a bad CPU to prevent power on. You can't trust the boards and builds some of the OEMs sell to provide normal diagnostic features like beep codes either unfortunately. Considering the specs on that beast, it probably isn't even worth your time to continue pursuing it. There's used PC places that sell better systems for so cheap in most big cities.
... I was just thinking back on that one I repaired at CCity again, and now I'm sure it was more complicated and I believe that it involved grounding problems which permanently damaged the first replacement MB. It was one of the more difficult repairs I have worked on, which makes the case for complete replacement even stronger. Good luck if you decide to continue working on it!
Any other ideas as to why it will not even power up? I really need to fix this computer as it for my friends uncle who has limited funds.
The power Switch & The LEDS are also missing. I am using a switch I pulled from a broken case. I know the switch works and I also tried it by shorting the two power switch pins with a screw driver and still a no go
I had my friend order another socket 478 CPU so when I get that part I can try both boards with the CPU and hope it works. I tried the board with three different power supplies and I know the power supplies I tried it with work
Thanks
When you got the replacement motherboard, what PSU did you first test it with, and did you test it in the case or outside of the case on the first try? I think that is what happened with the one I worked on, where the poorly designed case and motherboard combination was likely to have a grounding problem, and damaged the replacement motherboard right away in my first attempt to fix it.
You might be successful by replacing the CPU, as that is definitely one of the top 2 most sensitive components to electrical damage.
Is there any more information you can provide, or get from your friend's uncle? If the outlet it wasn't plugged into wasn't grounded properly and/or if there was a lightning storm the day before he noticed it wouldn't power on, then the whole thing is probably shot.
You may not be able to fix it and just have to apologize. I avoid doing most consumer PC support now because most people want help with really screwed up old systems, and aren't willing to pay much because of the age of the computer.
I tested the power supply and it works. I did not think to check the voltages though will do that on Monday (The PC is over my friends house) I do have another power supply I can try. So hopefully I can get the thing to work with another CPU
