DynDNS Help
nLinked
I am registered with the free Dynamic DNS service from DynDNS. I wish to use my new router which has DynDNS support. I have tried but require need some help.
I am only able to access my router via Telnet. There is no web interface. When I try to add a DynDNS, it asks for "name=". I enter myusername.dyndns.org.
I am then presented with the following to fill in. Apart from Password, I do not know what to enter for the others:
[intf] =
[user] =
[password] = ******
[group] =
[mx] =
[backmx] =
[wildcard] =
[offline] =
[service] =
[status] =
[trace] =
What shall I do for each?
since you didn't even provide the router version, I doubt you will get much help. Start by checking the manual for the router, and providing us with the router model/version
It's the BT Home Hub (in the UK). It's made by Thomson, and is a SpeedTouch router. It actually does have a web interface but DDNS is not in there. But DDNS is in its Telnet interface and all those settings are there.
