Hi,
Before my complaints, see my specifications:
- Athlon classic 650MHz (slot A)
- Mobo ASUS K7M (chipset AMD751 + VIA VT82C686A)
- ASUS v7700 Geforce 2 GTS Pure 32MB
- Windows 98 SE
- Directx 8.0a (Actually using Dx7a)
- SBlive
- 128MB RAM
- Nothing overclocked!
I'm using the latests AMD agp drivers and via 4 in 1.
The problem is: When I run applications that require D3D, like the playstation emulator ePSXe, it crashes, and the only solution is to reboot the PC! Then, I've unistalled the Dx8 and have reinstalled the Dx7a, and all the problems were resolved! Great, but I need to run some Dx8 applications, I need resolv this abnormal behave with Dx8! And before you say me to reinstall win98, I've just did it (HD formatted!) and nothing has changed, it can't resolv my problem. Help me!
ps: It only occurs with this Geforce 2, my old card (voodoo3) works flawless with dx8 in this same system!
- Windows 98 SE
- SBlive
- 128MB RAM
