Hi there,
I'm dualbooting XP32 and Vista64 Ultimate and am having some issues getting certain games to work in Vista. I have installed Crysis and Lost Planet on my Vista partition and am having the following issues:
1) the x64 exe for Crysis will not load. It goes to a black screen and sits there until I start task manager to kill it. The 32bit version loads fine (and I believe it is in DX10 mode).
2) the DX10 exe for Lost Planet (1.0.0.4 I believe, the latest version) will not load. Same symptoms as above (black screen). The DX9 exe works fine (in both Vista and XP32).
I don't think the problem is DX10 for the above games, because World in Conflict loads fine in DX10 mode with DX10 graphics enabled.
I have tried to install the Vista GeForce compatibility hotfixes (linked from the NVidia driver page) but only the memory allocation one will install. The other 3 (2x GeForce, 1x SLI) will not install as they say they 'do not apply' to my system (no idea why).
I'm using the 169.09 beta drivers for Vista 64.
Thanks for any tips, I'd really like to get x64 Crysis working to take advantage of my 4GB of memory. Lost Planet I just want to see the fur shader
