I can't for the life of me figure out how the hell to change to a non-integer channel, such as 48.1 for HD programming and 48.2 for regular digital. It only does 48.0
Not sure if yours is similar but on my ATI HDTV wonder I just do a scan and it will add automatically. If there is not enough signal it sometimes still gets the channel but nothing is displayed.
did you check to see if there is a .1 and even .2 in your area?
I used antennaweb and there's supposed to be a station 5 miles from me. The signal strength is 85 - 95% but nothing shows on the screen. I know that there's programming because every now and then I hear a bit of sound come through.
I get that too but its usually that there is no HD being sent over the line at that time. Check to see when they are broadcasting HD content and try it then.
I have 3 channels that are like that. When not broadcasting HD they dont send anything not even SD.
