Originally posted by: Matthias99
Originally posted by: knyghtbyte
hmmm...cant remember now, but if your dell monitor is the same one i got (its in the other room, gave it to my mum to use when i got new computer, i prefer CRT for gaming) then you dont wanna plug both DVI and VGA in to it....i think it can cause problems.....i remember when i got it reading a sob story about someone hooking both up and the monitor went dodgy.....and dell wouldnt replace cuz it does warn in the manual not too.....
i'll find out when i can if mine is same model, if it is then i'd advise you dont hook two cables up to it....lol....
its the 19in flat panel, Ultrasharp model yes?
edit: havnt found the monitor model yet btw, but it might have been the same computer connecting via both DVI and VGA was bad....will try and get hold of the guy it happened too...shouldbe on msn eventually....lol
I looked at a couple of the manuals on Dell.com. None of the 19" LCDs say you can't use both the DVI and VGA connectors simultaneously (also, the button with the little monitor icon and an arrow is the 'input select' button; of course, with only four choices, it's not hard to figure out).
Some of them say not to hook them both up to
the same computer, but even that should not damage the monitor. It's not like the monitor can tell that both the video feeds are coming from the same computer.
