JaYBirD0613
I have a 9700 pro that I've been using for dual LCD monitors. I've tried using the DVI port numerous times, but it doesnt work on any LCDs. The strange part is that if I use a DVI-VGA adapter on that port, it will work with a VGA cable.
So obviously the port is able to send out the signal, but for some reason it wont display using DVI. And yes, I've tried multiple DVI cables.
Any ideas as to what could be the problem?
