DVI Output to VGA Input Help?
RobDMB
I have a cable box that has a dvi output located on it and I would like to try to connect it to a vga monitor to watch some hi definiton programming. I am wondering if this is possible without a real expensive transcoder. Can a dvi signal be converted to vga? Thanks, Rob
Also one more question. Can you get hdtv content over component cables or do you need dvi/vga/hdmi to achieve hdtv output?
