Dvi Output Card
Arggg
Hey everyone, I am looking into buying a new DVI card for my lcd. I want the lowest price possible that you know of that would have dvi output. Right now, I have a Geforce4 MX420, which has no dvi output, and is avg. I want something that is as close as you can get to the performance of it. I dont want to spend more than $50-60 if it's possible. Thanks.
This Sapphire Radeon 9200 would do the job nicely. While it doesn't have lots of 3D gaming power (but still enough for a light gamer) it has the excellent 2D from it's older siblings.
-Por
I've had the same problem last week, and went for this card. Comes with SVideo-RCA pigtail adapter and a DVI-VGA adapter dongle you won't need. 45 euros, should be around $45 just as well.
There are no image quality differences on DVI. It's a digital signal - it either gets there or it doesn't. If it does, it's 100 percent pixel perfect.
Well.. I do play ultima online, will the g450 be worse than this geforce4 mx420 i have now? I really don't want it to be worse.. i just want it to have dvi.
