DVI input on a Trinitron - better quality than analog?
tk149
7,253
I have a IBM P260 monitor (Trinitron flatscreen) that has two video inputs:
1. a standard 15-pin (HD-15?)
2. a DVI (it looks like 24 + 4 pins???)
If I get a new video card with DVI output, will I actually see a quality difference? Or is the quality difference only for LCD screens?
And if DVI would give a better picture, what's a good CHEAP ($30-$40) video card to get? Mostly just for web-surfing/email.
Boogak
3,302
I've got that IBM P260 and yes, it has both DVI and analog input. I've tried it with both and honestly, I can't tell a difference. So I recommend saving your dough and keeping the card you got now.
FacelessNobody
314
Originally posted by: Schadenfroh
wth? crts have DVI?
Some do, yeah. The discontinued NEC FP1375X had it. For TK149, ask yourself this: Why in the hell would I want to hook an analog device up to a digital signal anyway? Also, I remember the NEC being limited to displaying 1600x1200 when using the DVI connection, but with the analog connection it could display 2048x1536. DVI, in my opinion, is taylor-made for displays with a fixed number of pixels.
Peter
9,640
The potential gain is that there is no signal quality loss in the path from the graphics memory right up into the CRT's video-in circuitry. With analog VGA cabling, the loss starts as soon as the signal leaves the card's RAMDAC.
jjyiz28
2,901
if a crt has a dvi option, dvi is always better visual quality than a hd15.
Jadow
5,962
my NEC FP1350X has DVI, and I LOVE IT!
I have tried but DVI and analog, and DVI really is better!
tk149
7,253
Any other comments? BTW, I'm replacing a Matrox Millenium (4MB) PCI video card. Hopefully with something with 32 MB.
Peter
9,640
Do you need PCI or AGP? Anyhow, there are Radeon-7000 and maybe still 7500(LE) cards that have VGA, DVI and TV outputs (dual screen capable) for either. They should have come down to your price range by now.
tk149
7,253
Sorry, I meant to say I want an AGP card.
beatle
5,661
It is true that the signal would stay digital until it gets to the monitor, you'd also be banking on the DAC in the monitor to be superior to that on your card. I wouldn't imagine it to increase quality very much.
zsouthboy
2,264
Those are available in AGP formfactor... check pricewatch..
