DVI doesn't work on Sapphire Radeon 9200
t3h l337 n3wb
2,698
I just bought an AGP 128MB Sapphire Radeon 9200 for my HTPC. It worked fine with my VGA CRT, and installed Windows 2000 and the driver that the CD came with. I chose to use the included CD drivers instead of the Catalyst drivers that I found on the AMD website for the 9200 because the ones from the website said Windows XP. It worked fine, and I installed a game and played it. Then I tried to connect it to my TV with a DVI -> Component adapter for ATI cards. It didn't work, but I did see a flash of the Windows 2000 loading screen in blurry black and white for about a second while I was rearranging the cables. Then I tried using a DVI -> VGA adapter to connect the monitor, but that didn't work either. Should I try using the up to date Catalysts instead? Or is there some setting I have to change?
MDE
13,199
The Windows XP drivers should also work on 2000. I'd give that a try first.
t3h l337 n3wb
2,698
Nope, that didn't seem to work. The DVI -> Component adapter says it only works for 9500 cards and up, but some people have said they've gotten a 9200 to work. Still, DVI -> VGA should work just fine though right? I use the same adapter on my desktop.
Auric
9,591
Some low-end cards only have DVI-D (digital) rather than DVD-I (digital and analog).
If it must be replaced, consider one which has a mini-DIN to component output rather than hoping for adapter compatability.
t3h l337 n3wb
2,698
Okay, I just checked, and it's definitely dual link DVI-I. So what could be causing it not to work?
Auric
9,591
Even if it is not compatible with the component adapter, the DVI to VGA should work. I'm stumped. Good luck.
t3h l337 n3wb
2,698
Thanks, I emailed Sapphire about the problem. I heard their customer service sucks though, so I probably won't get a very good response. Maybe I'll have to RMA the card...
VirtualLarry
56,587
10,225
I had an FIC AGP R9200 64MB card, and I never had a problem with the DVI-VGA adaptor on the DVI-I connector. Perhaps something is defective with your card.
