Hi guys, i need your help again. D:
So i finally assembled my pc, but got strange problem with monitor. So:
1. I put DVI cable into HD7850 and monitor shows no signal.
2. I put DVI cable into motherboard (GPU removed) and monitor shows no signal.
3. I put VGA cable into motherboard and i can see bios, everything is fine.
I know for sure that HD7850 and DVI cable both are fine - tested on other system.
You may say it's power supply, it's Corsair CX430 - should be enough? Either way, if it's not working when DVI cable into motherboard then it prolly has nothing to do with PSU?
What else remains? Faulty motherboard DVI connector or faulty monitor DVI connector?
