DVI cable
lupi
I need to get a dvi cable for the westy lcd I just bought and browsed at monoprice after only seeing $55 belkins in the local stores.
There seem to be a couple different types; what am I looking for?
Hum well I have seen DVI-HDMI and HDMI-HDMI at both Walmart and Zellers. 6 foot ones range from $25-$35 and then 12foot ones are just slightly more. Phillips and Belkin ones. Either will work for you... I know the Belkin ones state HDMI 1.3 but I believe both are and makes no diff.
Either that or online... some companies are really cheap if you order that way... just do a search on Google and then find one in your country.
Originally posted by: Cabages
I think hes just looking for a straight DVI.
Here's a good place that explains them.
This is the one I have.
Here's something like it at monoprice.
Hope that helps.
Yep, that's what I was looking for. Wanted to get it through mono as I would be ordering the Wiimote charger at the same time.
