DVI cable question
slick2004
227
would using a NON dual link dvi cable effect the way a 60hz lcd monitor works, as opposed to a dual link dvi cable?
Mem
21,476
13
Only what res you can use,
Dual Link: Dual T.D.M.S. (transition minimized differential signaling) "links". DVI can have up to two TMDS links. Each link has three data channels for RGB information with a maximum bandwidth of 165 MHz, which is equal to 165 million pixels per second. Dual-link connections provide bandwidth for resolutions up to 2048 x 1536p.
Single Link: Single T.D.M.S. link. Each link has three data channels for RGB information with a maximum bandwidth of 165 MHz, which is equal to 165 million pixels per second. Bandwidth for a single-link connection supports resolutions of over 1920 x 1080 at 60 Hz (HDTV).
Moe info @hexus here http://www.hexus.net/content/item.php?item=4455
