DVI Cable, How long can it be?
sep
2,553
I need a cable longer than the standard 6ft cable I got with my monitor. Anyone know where I can pick these up? Also, will I have problems with one longer than 6ft?
thanks,
-JC
rbV5
12,632
I've seen Fiber Optic DVI cables @ 100 meters, but IIRC, you should be good to 5 meters with a standard cable without repeaters. I've used CablestoGo for some of my HTPC cabling.
Solutions
90
I am using a 25ft DVI cable for my HDTV. Got it a circuitcity for around $100 (Monster Cable). Real pricey and probably overkill but I have not noticed any signal loss or poor quality due to the cable length. I am also using 8 25f+ VGA cables on a multiple-monitor workstation with the same flawless results. No repeaters or anything like that are being used. All nVidia video cards (AGP, PCI).
So, you shouldn't have any problems using a DVI cable longer than 6ft. I used Cables2Go for my VGA cables. Decnet company.
PurdueRy
13,837
4
yeah monster is not overkill its overpriced. Next time save yourself some money and shop for BETTER and CHEAPER cables. For sites PM me
