- May 19, 2004
- 32
- 0
- 0
I've got the LG GSA-4082B 8X4X12 DVD+-R/RW/RAM 24X16X32 CDRW. It was installed correctly, and functioned 100% for a couple of weeks. I have not made any significant additional hardware or software installations in the last few days (a couple USB devices, nothing else really).
Beginning last night, though, I've got a problem.
When put a blank disc (DVD or CD) into the drive, and try to access it, I get an error that reads: "E:/ is not accessible. Incorrect Function".
This is when attempting to access it via simply double-clicking the drive (rather than using third-party software). When I try to burn from some other program (Alcohol 120% etc.) I simply get an error saying that burning has failed.
In Windows, it still does seem to know (on some level) that there is a blank disc in the tray. It says either "CD-R" or "DVD-R" (on the icon) depending on what type of disc I use. But, it cannot access the disc.
The disc does still read audio and data information, and I can listen to music or copy stuff from discs. But, it cannot read blanks properly.
What are my options? What can/should I do?
Thanks,
Dave
Thanks,
Dave
