JM Aggie08 Diamond Member Jan 3, 2006 8,436 1,037 136 May 16, 2009 #1 Is there any way to convert .dvdmedia files into anything else, such as mp4, avi, etc.?
H hennessy1 Golden Member Mar 18, 2007 1,901 5 91 May 17, 2009 #2 JM Aggie08 try this and see if it works or helps you at all You just have to delete the file extension .dvdmedia and you get a simple video_ts folder that can be managed to whatever format you need.
