dvd won't read after first cd
KOZMOKRMR
I got one for you all.
If I put a dvd (cd) into my dvd on my computer and read it and then eject it and insert a new dvd (cd) into it, it reads the old cd information. It doesn't read the new cd and thinks the old one is in it. I updated the drivers package from the website and also flashed the bios to the latest (1.9 i think it was). motherboard is MSI K8N Neo4-F. 1GB Kingston PC3200 mem on two sticks, XFX 6600GT PCIe 128MB video, Win XP Pro.
Even when I click on the dirve, it shows the files from the first cd and then tries to run those files again.
thanks,
koz
Probably a software conflict. Avoid the use of multiple burn applications in the PC. Uncheck all items in MSCONFIG's STARTUP tab and reboot. Retest with DVD movies. If okay, then you may have a problem with the way your burn your data. Use ISO format only. Avoid packet writing stuffs.
excellent. i removed roxio's startup (3 programs) and nero's startup and intervideo's startup and wallah! no more issues. thanks very much.
koz
