DVD sound !!!
AngelDeath
83
this is the first time I am play DVD and the sound very good I mean very clear and surround effect is very sharp compare to the VCD but there is something annoying me ,the sound not loud as VCD do even I turn max the volume !What happen ?maybe is there any trick that I didn't know ?
I am currently using :
epox 8kha+
creative audigy x-gamer
headset LABTECH
Derango
3,113
This is normal on a DVD. The sound is normaly recorded at a lower volume than on any other media. Just turn your speakers up ;)
"Many people complain that the audio level from DVD players is too low. In truth the audio level is too high on everything else. Movie soundtracks are extremely dynamic, ranging from near silence to intense explosions. In order to support an increased dynamic range and hit peaks (near the 2V RMS limit) without distortion, the average sound volume must be lower. This is why the line level from DVD players is lower than from almost all other sources. So far, unlike on CDs and LDs, the level is much more consistent between discs. If the change in volume when switching between DVD and other audio sources is annoying, you can adjust the output signal level on some players, or the input signal level on some receivers, but other than that, there's not much you can do."
From DVD Review FAQ, section 3.6.2, last paragraph.
AngelDeath
83
there is no option like that ,but i found a headphone setting in creative software .If i max all sound the other sound like too loud.
