I just bought the Lite-on dvd+-RW from newegg.com. The bios recognizes the drive but it doesn't show up as a drive letter when I boot into xp.
I have the dvdrw and a dvdrom connected to the secondary ide channel.
When I check device manager I see both the DVDRW and the Dvd rom in there but they both have the exclamation mark indicating there's a problem.
My computer has a dual-boot setup with xp and win2k. When I booted up with win2k, both drives worked just fine.
I've tried uninstalling both drives and the 2nd ide channel from device manager and letting the os redetect them. No luck.
The DVDrom is set as the master and the dvdrw as the slave. I've tried the dvdrw by itself as the master with the same result.
I also tried putting it back the way it was and that doesn't work either.
Any help will be appreciated.
Thanks
Thanks
