Basically, my problem is this. I recently installed Windows XP on my Sony Microtower E308ds (P2 450, 128) everything works great EXCEPT my DVD-ROM (Sony DVD-ROM DDU220E). It plays CD, CD-R, and CDRW fine. However, when I insert a DVD movie into the drive, the autoplay doesn't pop up, and when I goto My Computer and try and access the drive I get this error: "D:/ is not accessible. Incorrect Function."
Here's what I've done:
Tried uninstalling, and reinstalling the drive, that didn't work.
Checked to make sure it's compatible with XP and drivers are up to date, everything is fine there
Made sure I had right Mpeg Codecs and UDF 2.01 which comes with XP so that shouldn't be a problem.
Software decoder: tried both XP media player and PowerDVD, neither recognizes any DVD movie discs.
Asked microsoft for help, asked sony for help, looked for people with similar problems...no help.
I'm still not sure if it's a XP problem or a problem with my drive. I assume it's XP since everything worked fine with 98se. Any help would be appreciated.
Thanks! -Nate at UCLA
