wanderer27
Okay, here's my problem.
I have a Toshiba DVD-ROM SD-M1202 drive, that will no longer do the Autorun when a CD is inserted.
I can open the CD (after quite some time) and see the files on it, but if I click on the Setup program on it (CD), I get an error. Also, some of the Icons just have the "generic" executable Icon. From past experience, I've had very little luck getting a program with this type of Icon to work properly.
The drive worked previously on this Computer fine in DMA mode. All I did was change the DVD to Slave on the IDE bus, and the other Device I of course switched to Master. I then reformatted the HD as it had been partitioned (98SE & XP) so I had a single partition.
Now if I switch the DVD to PIO Mode, it will work, at least with CD's, I haven't checked DVD's yet. Running the drive in PIO Mode is not really a solution, this is a DMA device and should run as such - it did before with no issues. I also don't want to take an unnecessary performance hit when I shouldn't have to.
I'm using XP Pro SP1.
This is on my second Computer, not the one in my Sig.
Any thoughts/ideas on where to go here ?
