DVD Ripping Questions - DVDFab, Formats etc
rprice999
79
I have done a lot of searching but I can not find the answer to these questions...
I am ripping DVDs to my Home Theater PC to be played in XBMC. In terms of QUALITY, which is the better option, to rip as a DVD5 Size .VOB copy or to encode as an .MKV/H.264 file?
The VOBs are nice because it's easy to burn them back to DVD if I ever need a local copy but how does the quality compare to an h.264. Does anyone know? Are there any other pros/cons?
Kaido
Feb 14, 2004
51,769
7,320
I just use ISO's. That way you get the extra menu goodies and you can always burn back to disc if you need to. 4 terabyte drives are $299 these days, so you don't really need to spend thousands of dollars on a storage system anymore.
I'd say do a side-by-side comparison of shrunk-VOB vs. MKV. My guess is that MKV/H.264 will give you better quality because it's meant for compression, plus a lot of players support MKV now, which is really nice. If you need to burn the MKV to a disc, just use DVD Flick.
Anteaus
2,448
4
My preference is to rip using MakeMKV and then reencode using Handbrake x.264. If you tweak a bit you can get near perfect encodes. It's easy enough to decide which extras you want to keep and reencode those on individual basis.
I don't like ISOs because it forces you to store needless data. With a few DVDs it's not bad, but when you're storing hundreds of titles that extra fat really adds up.
Whatever method you choose, consider future storage requirements and whether or not you are encoding merely for alternate viewing or actual future proofing.
smitbret
3,382
17
INB4 "Compressing is the devil!!!!"
Welcome to the wild, wild west. Where facts and absolutes don't exist and what works best for you may be useless to someone else. I can only tell you what works best for me.
Do you understand the difference between containers and codecs?
.vob and .mkv are containers. Think of them as just like tupperware. Other common container types are .mp4, .avi, .m4v, .mpg, .mov, etc.
The containers (.mkv, .mp4, .vob) hold audio, video and subtitle streams like .h264, .divx, .ac3, .pgs, .srt, .aac, etc. Certain containers are more flexible than others. .vob containers are a DVD standard and accept an MPEG-2 video codec and an ac3 and/or dts audio stream plus any subtitle streams. You could unpack those streams and put them into an .mkv and the quality will be exactly the same. Just like if you take macaroni out of a bowl that says .vob and put it in a different shaped bowl that says .mkv. It's the same macaroni.
When you shrink a .vob file, you are transcoding the MPEG-2 video stream and the .ac3 or .dts audio stream and reducing the bitrate. This is where the quality goes down. If you have a 6GB .vob and want it to trancode it to a DVD-5 .vob you are just removing information from the streams to make them smaller. Some material compresses quite well, some does not. Simple animation compresses very well because of the lack of detail, but action movies with lots of dark scenes do not compress well at all. You get artifacts as the codec tries to guess about what should be displayed and your dark scenes get blotchy and blocky.
.h264 compresses much more efficiently than MPEG-2 at lower bitrates. A 4GB .mkv with an .h264 stream can be of much greater quality than a 4GB .vob. By the same token, .aac compresses much more efficiently than .ac3. You can make the .mkv as large or small as you'd like.
Size of playback screen is the biggest factor. If you are on 110" projection, then ANY compression will probably be noticeable. If you are watching a 32" from 10 feet away, then any reasonable compression will look the same. Keep in mind, with DVDs you are are also getting upconversion if you display it on an HD TV. The more info the upconverting device has to work with, the better the upconverted image will be.
.iso is a container type, but it is just basically packing a photograph of the original into the .iso file. It will take anything but requires special and unpacking.
If you want to keep all of the menus and goodies then an uncompressed .iso is the best option. The .iso will run just like you stuck the DVD in the player with the exact same quality.
If you just want the movie and space is important, the size of the TV will be the biggest factor. On 110" projection, any compression will be visible. If it is a 32" that you watch from 9 feet away, you can shrink the movie itself down to about 1GB with an .h264/.mkv and probably won't notice the difference.
I personally have 1 DVD player in the house that hasn't been used in 3 years and the next menu or DVD extra that I watch will be the first one. I don't anticipate DVDs making a comeback either so I eliminate any necessity for .iso or .vob.
I do not have a $10,000 Dolby THX certified audio setup on the main tv. I do have 4 tvs from 17" to 50" connected to a combination of PS3, WDTV Live and DirecTV receivers that playback my movies stored on a central computer. The kids also like to watch movies on the 7" Kindle Fire. Occasionally, there is a need for the movie to be on another portable device like an Android phone, so I try to make my encodes compatible across the entire field if possible. So, while .mkv is the most flexible format, not every device supports it so I go with .mp4 or .m4v.
I rip Movie Only from the DVD or Blu-Ray as an .m2ts or .vob file using DVD Shrink (DVD) or Tsmuxer (BR), keeping the original video stream and the 6-channel .ac3 or .dts audio stream. I run them through Handbrake and use .h264:
DVD - 1200-1500kbps
720p - 2200-2500kbps (Most of my HD rips)
1080p - 6500kbps (My favorite handful of movies)
I insert 2 audio streams. Some devices (like an Xbox and lots of portable devices) will insist on a 2-channel .aac as the first audio stream or the file will just crap out so the first is always an .aac 2-channel at 128kbps and the 2nd is usually a 6-channel .ac3 at 448kbps or 640kbps if I think the extra bitrate might be needed in the future. I might keep the .dts instead of an .ac3, but I'm back and forth. I use no more than 4 reference frames, the PS3 will choke on anything more than 4. I also set 3 b-frames. The rest of the settings are dependent on how fast I need the encode to be done versus how much that last 10-20% of quality matters to me.
Ultimately, your best bet is to just tinker with it and find what works best for you.
rprice999
79
Great info here - thank you!
Smitbret - you are very thorough, completely answers my question, thank you!
Anteaus
2,448
4
The title is misleading because they ruling doesn't ban copying DVDs, only how the media is used post-copy.
It says "...has ruled it's illegal to bypass copy-protection in order to make digital copies for playback on hard drives, tablets, phones, and non-disc devices."
It says nothing about backups, which is still legal per the DCA. The problem with the ruling is that it is too little too late, because it is completely unenforceable.
Anyways I'm not sharing an opinion just wanted to clarify what the ruling actually means in real terms. Good luck everyone.
smitbret
3,382
17
I wasn't aware of that new ruling. I will certainly cease and desist as well as completely uninstall the devlish SlySoft software product that is known as AnyDVD HD.
