Question DVD drive not open tray
gamerfan
My Samsung DVD drive does not open the tray Is it possible to repair it without opening the drive fully? it only opens with a needle or wire and for it to close I need to touch the tray after pressing the button
Have you tried both "buttons"? The physical one and the "right click and eject" one?
I used to have a player that would only eject through the software button.
Are both the data and power cables fully seated on both ends? I would try reseating the cables at the drive/motherboard then the drive/power supply.
Once you have confirmed that the cables are seated, try these troubleshooting steps:
There is probably a rubber drive belt for the tray motor. It may need to be replaced. You can usually find universal belt kits for a few dollars.
