Following Setup:
Win 2000
Epox 8KTA3+ Motherboard
BDV 108A DVDROM
WinDVD + PowerDVD Both have same problem:
My problem is that my DVD Software (WinDVD & PowerDVD) doesn't work due to DMA related issues.
To get full benefit out of my harddrive (ATA100) I have to install VIA Bus Master Ultra ATA Controller (Software that came with my board), and after installing this I get the following in the Device manager:
IDE ATA/ATAPI Controllers:
- VIA BM Ultra DMA Channel
- VIA Bus Master Ultra ATA Controller
None of the two DVD programs works and claims that the DVD drive is not using DMA. When checking under properties in "VIA BM Ultra DMA Channel" there are no PIO versus DMA options, so I assume that they are using DMA.
If I uninstall the controller I get the normal stuff under IDE ATA/ATAPI Controllers, and I get the choise between PIO and DMA, and both the DVD programs work again.
The big problem is that my harddrive performance sucks when the controller is not installed.
Is there a way to fix this problem ?
Win 2000
BDV 108A DVDROM
